show snmp traps bfd
show snmp traps bfd
Description
This command displays session up/down trap reception for BFD.
Syntax Description
snmp Configure SNMP specific settings.
traps Configure SNMP Trap generation settings.
bfd BFD-specific traps.
Default
Not applicable.
Usage Guidelines
Use this command to display SNMP trap reception for BFD session up/down.
The following command displays SNMP Trap configuration for BFD:
#show snmp traps bfd
SNMP Traps for Session Down    : Enabled
SNMP Traps for Session Up      : Enabled
SNMP Traps Batch Delay         : 1000 ms
This command was first available in ExtremeXOS 15.5.
Platform Availability
